There will be about 10 ten people there I rekon.
Mundine Vs Green is on, everyone will be at home watching that!
All the more reason to race then as less cars supposedly = more runs.
That being said, I still think you'll find a decent amount of cars there this Wednesday testing for Compack Attack on Sunday.
Should be a good night :thumbsup:
https://www.sau.com.au/forums/topic/117864-wsid-17th-may/#findComment-2169912
I have thought that many times but in regards to the state of origin footy - i was wrong - last time the entry cars were maxed out - full night !
https://www.sau.com.au/forums/topic/117864-wsid-17th-may/#findComment-2172816
Interesting night for me...
Started off with a few shocking passes, but eventually nailed a few PB's in the low 12's, then finally got that 11 sec pass on my last run of the night - 11.949 @ 118mph :thumbsup:
I'm stoked! :D
Nice to meet you 4door GTR (didn't get your name) and thanks for the numerous tips Ben - got there eventually mate ;)
https://www.sau.com.au/forums/topic/117864-wsid-17th-may/#findComment-2177125
I'm stoked! :)
Nice. 11's are good. ;)
https://www.sau.com.au/forums/topic/117864-wsid-17th-may/#findComment-2177729
Well done on the time, BOOSTD.
2nd hand boxes are a bit of a lucky dip. My first R32 box didn't last past 2nd gear when it saw boost for the first time. DiRTgarage has an R33 GTR box for a good price in the for sale forum.
https://www.sau.com.au/forums/topic/117864-wsid-17th-may/#findComment-2217914
    • I was using the wiring diagram I have So 12.74V is coming into the rear Fuel Pump relay as I measured.  When I turn the key to ON im getting 0.6V to the Fuel Pump plug; which i assume is backfeed voltage and doesnt include the 12V from ignition power.  The rear relay is working and being triggered.  From the diagram I clearly see the rear relay 80 = Rear Relay going into the Body/H loom (R-27) 27 = Fuel Pump plug going into the Body/H loom (T-20) 40 = Short Connector (R-27) I'm reading 12.74V on the blue/black wire which is the power for the Fuel Pump   From this diagram I can see the Ignition relay goes into the front and up to the ignition  2 = Fuel Pump Relay <1M> (R-27) 37 = ING Relay <1M> I started from the pump using this reference Which the way I read it (referencing Nissan wiring color codes) is: Pin Wire Color Function 1 B/P (Black/Pink) Ground 2 L/W (Blue/White)        ECU Trigger 3 SB (Sky Blue) Fuel Pump 5 L/B (Blue/Black) 12V Constant Tested SB to SB on Fuel Pump for continuity - confirmed Tested negative on Fuel Pump to 12V battery and L/B - confirmed 12V Pulled the relay putting 12V between Pin 1 & 2 and testing continuity on Pin 3 & 4 - confirmed relay   So that has me looking at this part of the circuit to understand whats happening here...and im still confused. From best I can tell; the disconnect is back to my previous diagram; between Ignition Relay and Fuel Pump Relay...which yet again; afaik is where the immobiliser should.    Thats what I was trying to explain to GTSboy; im not trying to fix it myself; yet I seem to have to get a Masters in Electrical Engineering (while im busy doing my actual job of DevOps & Cloud Engineering) somehow.  I just wanted more expert opinions; or more so that what I tested is correct and proves it to something around that area; to go back to the alarm tech (for a 3rd time) that he needs to fix it. He keeps telling me its not the alarm. He lives on the complete other side of the city so i understand not wanting to make a trip but as I said before if its the alarm it should be up to him to fix it. But he's adament its not; even though I pointed out the FP was immobilised through the original alarm. To my mind; it seems that the ECU is sending the signal; but the ignition is not getting 12V down the line.
    • Maybe also really stiffly sprung track cars. Get the inside wheel up in a corner and all the fun stops. Also me sometimes (rarely) when I have to stand on the brake to convince the diff to drive the wheel that is still on the ground when I'm trying to diagonally get over severe driveway entrance, etc.
    • I feel like I'm missing something. You had an authorised installer come out and install a new alarm. Post install the car doesn't start, and you aren't getting the installer back to fix what they did wrong?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
