Hey guys have the following parts for sale.
RB20 intercooler with all factory air ducts $70 ono
R32 Complete A/C system ( condensor,compressor, plus all fan motors etc) $200 ono
R32 Power steering system ( resevior, pump etc) $100 ono
R32 Windscreen washer bottle $20 ono
R32 Overflow bottle $20 ono
R32 Steering column with key $100 ono
Cheers Dave
Edited by dlen77
https://www.sau.com.au/forums/topic/117876-fs-r32-gts-t-standard-parts/
Hi dlen77, i'm after a rubber elbow which i think is from a rb20det. A mate from tafe gave this elbow that was almost 90degrees, but it had this big foam boot sort of thing around it with sections cut out. Anyways, i'm after another 1 of those cause the inside diameter is damn close to 60mm which is what i need. If you have 1, could you send a pic and what sort of price you might want. Send any pcs to [email protected] Thanks
PS, i tried to PM you this but i dont think my PM system is working properly, nothing goes into my "sent" folder
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
