Hi Folks,
I run a nice set of 18" Zepter Mesh wheels and getting them clean can be a royal pain in the arse, but they look fantastic when they are.
However, keeping them that way can often be the biggest pain of all and the biggest culprit is that damned nuisance, brake dust! You know the stuff I'm talkin' about.... wash the car today and in two days time the friggin wheels are almost black again!!! :)
I'm up for a set of brake pads very soon and wanted to see whether anyone else has factored "brake dust" into the equation when selecting pads.
Speaking to a friendly, knowledgable fellow in a local brake shop the other day, he suggested that EBC Green Stuff Pads offer excellent performance with negligible brake dust. He reckons they've had a great response from clients that have complained of the same problem, particularly drivers of expensive euro cars.
Wouldn't mind something that could handle the odd track day once in a blue moon, but ultimately I'm just looking for a high performance street solution, not kamakazi race pads.
Does anyone have any experiences / preferences that they would care to share?
Cheers,
Mike
The EBC greens work quite well and the dust is low, great for street pads for sure.
I use reds on the front and greens on the rear. Reds dont dust too bad either.
work well enough for me using them in bitumen sprints. Bite well from cold too.
Gary
I have a pair of Project Mu HC Titan Kai in mine.
they are super good and dont give out a lot of brake dust.
Grab very very well no matter what the temperature.
Don't go with RB74's if you don't like dust.... :woot:
I just purchased some Ferodo DS2500's... will let you know how they go, dust-wise.... though they'd probably fall in your "Kamikazi race pads" category
Um, the RB74's I use on the front generate far less dust than the pads I use on the rears - which are Bendix ultimates.
I use rb74's and they are low dust on the street.
They will handle the odd track day too.
Most pads ive seen either - dusty (cos the pads wear fast), or non dusty (cost they chew the rotor out more so than the pad)
Edited by Bl4cK32
Don't go with RB74's if you don't like dust.... :ermm:
Bwhahahaha.
DS2500's? I hope you like gunmetal wheels, because that's the colour they're going to be after a few days.
Are your's really really really loud? I had the same pads in my old 33, with slotted rotors. They were an awesome peforming brake pad, but the squeal mine let off was SOOO loud. Louder than trucks. I had to take them off as you couldnt drive with them on the street, if you went in an underground carpark you would literally have to block your ears. i tried re-bedding them but nothing changed. But apart from the sound best brake pads i've used so far
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
