I just noticed that inark and GODFATHER (spelling) are the moderators for this section.
Neither of them post very much and i think that I could post anything up that wouldnt be moderated becaue they are not active anymore. but thats not the point...
is it time we got new and more active moderators for the ceffy and other RB section ??
give opinions :thumbsup:
https://www.sau.com.au/forums/topic/117973-new-mod/
I was just thinking it would be so easy to be a post whore or post up crap (something like needed new mods :D ) without anything being done about it.
Many valid points, I don't think one is totally needed as we do tell people if they are being a knob.
Might send some Pm's and see whats going down in mod land.
Nb. And huddy, expect to see my car sliding around september with 2 way diff and twin 4in tip exhaust :P
https://www.sau.com.au/forums/topic/117973-new-mod/#findComment-2170516
although one reason i think a mod is still needed, or just this sub forum needs to be retitled is to stop people asking questions that are motor specific or just general questions that would be better answered in the tech or general areas. This is mainly for cefiro and other 4 door sedan 'specific' questions and discussions, not about general rb20/25/26/30 q's. Hopefully ppl understand what i'm getting at......?!?
Edited by skypy12
https://www.sau.com.au/forums/topic/117973-new-mod/#findComment-2177037
  • 3 weeks later...
dangerous_daveo has been made the new mod for this section. Also the section and its description have been altered.
Each section can have up to 3 moderators, so I will add another mod in due time.
https://www.sau.com.au/forums/topic/117973-new-mod/#findComment-2235686
I'd like to make the suggestion of Bringing the 'Members Rides' Thread back on the front page.. As it seems it is a little tucked away where it is, hence why I think so many people lately are using the 'Tough Cefiros & Other 4drs ' thread to show off their car.
https://www.sau.com.au/forums/topic/117973-new-mod/#findComment-2269117
Agreed Drift_Limo, putting all those below threads as a separate sticky link would be better then been hidden in that one "Sticky: All Sticky Threads are in HERE" link.
MEMBERS RIDES
http://www.skylinesaustralia.com/forums/sh...ead.php?t=47237
CONFUSION ABOUT UR RIDE?
http://www.skylinesaustralia.com/forums/sh...ead.php?t=53585
DYNO SHEETS
http://www.skylinesaustralia.com/forums/sh...ead.php?t=48064
RULES
http://www.skylinesaustralia.com/forums/sh...ead.php?t=48513
MEMBERS INSURANCE
http://www.skylinesaustralia.com/forums/sh...ead.php?t=47235
CEFIRO SPECS (incomplete)
http://www.skylinesaustralia.com/forums/sh...ead.php?t=48807
Edited by skypy12
https://www.sau.com.au/forums/topic/117973-new-mod/#findComment-2269141
MEMBERS RIDES
DYNO SHEETS
RULES
MEMBERS INSURANCE
lol i didnt even know they were there :D
https://www.sau.com.au/forums/topic/117973-new-mod/#findComment-2269423
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
