Just bought the young fella his first trail bike and keen to take him out to get a face full of dirt and some gravel rash this weekend, but I have no idea where to go.
Anybody know some good spots out of town a bit where no-one cares too much if we putt around on unregistered bikes?
If you don't want the whole world to know about a fav spot, PM me maybe...
Thanks!!
https://www.sau.com.au/forums/topic/118300-places-to-ride-in-the-act/
ok Brindabellas, Captainsflat, Cowrin Forrest near QBN. Back of Tharwa is also possiable but shit. YOur best best would be Cowrin but some of the trails there are a bit much for a newbe.
Thanks for that. Can you give me a rough idea of how to get to Cowrin Forest, i've never heard of it before?
sure, its just near yass road QBN, near the motocycle training ground on sutton drive I think thats what its called. Just near the turn off to Oaks estate.
If your heading into QBN via the road past the air port, its left just after the oaks turn off, then about 1k up the road is a parking spot.
There are heaps of different areas in there, lots of tight single tracks, or open fire trails. Dont get lost!! and watch out for mountain bikers.
As for the place near braidwood, its Mr Griggs and there is a track there, plus heaps of open spaces just dont go on the areas marked no bikes. That place is pretty good and all for a donation and sign a vayver.
Edited by race_snooze
  • 3 weeks later...
Sorry to dredge up this post again, but can anyone tell me exactly where/what/how to get to the place near Captains Flat?
I think it's on someones private property, like Larbert near Braidwood is. Tried Googling it, but SFA.
Thanks
I cant help you, i was always a passanger never the driver so i have not remembered. All i can remember is driving up the hill out the back of QBN main road to Bungindore. Then turning off somewhere. Its Crown land too not privete.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
