Hey guys
For sale is an ARC smic designed to replace the stock side mount cooler in an R32. It is in good condition and bolts straight on. Depending on how different R33/34 piping or mount location is, it may fit these models also. But orignally purchased for an R32
$275.00
Contact Phil on 0438 768 009
Edited by 180_mph
https://www.sau.com.au/forums/topic/118788-arc-side-mount-intercooler/
