  • Replies 133
DCEIVE: yep, used in 2000 classic rally i believe
id say it did do 13s or better when c-red had it
but i suspect they used a bigger turbo :)
you buy your car from AutoCo? they seem to have had a couple of hr31's and a dr30 too i think...
Nate: my car currently has a blown gearbox
doubt that it will be repaired in time :D
Bummer, cruise is for early May now though :D w00t, i got my exhaust all off and chopped up n stuff now, and the air pod connector and heat shield getting made for me :D For freeeee!! My dad is a boilermaker, he can make that for me for nothin, was $40 in marlows just for the pod connector :D
hey hako, yeah they had one ages ago but that was sold when i went there. they brought in two more, i bought the 4dr manual and i think they still have a two door auto for sale. i think the guys there are keeping the dr30, they didnt even let me look at it.
DCEIVE, is your GTS a 2 or 4 door?
I think I have seen it around. There was a 4 door one for sale in auto trader a couple of weeks ago for $9,000. I begged my b/f to buy it but he said no. He bought a Commodore instead.
If you need info or parts or anything you should call my Dad at SST. He has my old R31 GTS-X and Jayson takes his R31 GTS-X there too. He also gets heaps of other model Skylines. Dad specialises in Skylines so he knows a bit and knows where to get parts etc.
Well, if I can't put in a good word for my Dad ya know, thats a bit harsh!
I have seen Tods DR30 and it looks awesome! That display is gonna look good Dad! Hang on a sec, thats right, you arn't my Dad, I was the posties!
  • 4 weeks later...
Miss Sillouette, why don't you come join our R31 cruises and other club days (motorplex this weekend!) You are more than welcome and there will be finally a girl to keep me company. (I was only girl last night).
Guest Miss Silhouette
That sounds great! I would love to join in cruises etc. Where can I get the info of upcoming events? From this forum? When do you meet at Motorplex? Is that the Street Racing on Sundays? Sorry, lots of questions!!
Yep, we have our own lane booked on Sunday at 11.00am (1st June)! The next cruise is not yet planned, all are waiting to hear that from Ben. I will keep it posted here but there is a site www.r31skylineclub.com and they are getting a site up and running for the WA members! So if you wanna join, you are welcome! We have about 15 people now and more are always welcome!
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
