what land release? I went to the launch of that settlers cover at berado's a bit back it doesnt look to bad...I want to know what they bought the land for though? Any idea's?
about 10 mins or so from coolum, not a bad little estate, small though, 6 have already gone pre release
You go into 'my ebay' where it lists the item you won theres a little drop down menu (from memory its next to the price an stuff) that you can use to 'mark as payment sent' or some shit. Plus i always email the seller to let them know i put the money in their account, when i expect the transfer to go through, what reference name i put in the transaction etc..
Also i think ebay has its own messenger system (like when you 'ask seller a question') it goes thru to them like a PM on these forums, plus i think they get a email aswell..
cool as, thanx for that.
i will email him on monday to let him know i have deposited the money in his account.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
