http://cgi.ebay.com.au/NEW-SKYLINE-R32-R33...1QQcmdZViewItem
Why not get a split dump like that one? supposed to be better i think.
so not far then, i'll grab one of the fullli hektik qml toyota carolllas and we'll go do some skids somewhere lol
looks neat. Does it come with gaskets??
nah no gaskets. just like that. butil just get the exhuast shop to put wem on when i get it installed, i tried to undo the front pipe on my exhuast on friday at work, but it was locked on tight, so il just get the exhuast shop to do it for me, i didnt really wanna brake any studs off or anything while i was at work.
yeah i lookedat them aswell, but after i talk4ed to the guy at the exhuast shop, he said they are good, but he has seen a few split round the welds from heat and stuff, and bcoz they have more welds on them, its more likely to happen than on the one i got so i just went with the safer option.
I've never seen a v35 in the flesh..
/insert rant about migrane headaches and how they suck right now :)
il show u one if there is still one up here when u come up (if u havent seen one before hand)
i know where there is a few actually.... just hope they are still where i saw them.
i dunno, arent they non turbos... i couldnt live without my turbo
yeah they are, but they are a nice car, leather 4 seater in the 350GT coupe but it would have to be a manual.
Available with the same 3.5L VQ35DE (NEO) powerplant as the Nissan 350Z, and pushing out 272 ps (200.06 kw) @ 6000 rpm and 36.0 kg/m (353.04 Nm) of torque @ 4800 rpm, the new V35 Skyline is capable of 0-100 in about 6 seconds.
There is even a 4-door performance version for those wanting 4-doors with performance, and if that is still not enough there is a twin turbo kit available for some SERIOUS power and definite street cred.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
