Arhhh well im spending 7 grand on the next stage of mods anyways... so whats a tripple plate clutch in the wallet
Please oh please dont get a triple/twin col. go speak to jim berry, the custom single he's doing for me is only costing $1200! and thats for the power level i want aswell
I ran a 13.4 with no 4th gear and a .988 reaction time so its got 12's in it right now... I just need to put the power down...
I could not get 4th due to the clutch not disengauging correctlly at high rpm.
What do you want for th clutch shane??? I mean what type is it and will it hold 400rwkw??? Lol
Ill be talking to jim berry tommorrow...
I have 300rwkw in mind at the end of the next round of mods so i need something to hold 400 at the fly wheel... Just so i got some head room. I dont really want another brass button cause its a daily driver...
yeh the one i've got is only rated to 300rwkw's as it is now, but with a bit of tinkering by jim it could see alot more, but as u said its ur daily driver so ud hate it lol
ask benjito how much i was cursin at it in the gtr lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
