Anyone got any pics of an engine bay painted in midnight purple or purple pearl?
Sooo cut, was going to take next week off to paint the engine bay (jet black with purple pearl) but the fella im doing this work for needs me for the next 2 weeks arghhhhhhh!!!!
Yeah for job interviews...
Im off for a few hours to go to a job interview to see if i cannot get more money than im earing now. I think its gonna be hard to get more money to be honest. Im slightlly over paid.... :devil:
where is everyone latley , it used to be this was the most whored whore town in Aust (mainly due to old schoolers like Ska & Chaos...) is there a fight club ? maybe I should have renewed my membership even tho I live in NT now (P.S Darwin Blows)
Well in short Ska has to work at work these days and has a busy family life outside work. Plus he is too busy in the stagea section of the forums.
Chaos does not post much at all anymore due to a disagrement and charley and other postwhores dont come round these parts much due to a "newschool/oldschool" arguement which would make a hooker blush.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
