what burnout :| It's dickhead teenagers doing burnouts on "Abandoned" bridges that give us import owners a bad name, I think some people need to gain some maturity, although i also believe that peer pressure could also have something to do with this isolated case.
well aphid, was the burnout on the bridge really worth it?
Edited by aphid
pfft..... i think mr alcohol has something to do with it to.. and a bunch of little preteens on the side of the road screaming "" spool it ya fools//
"He won't spin it up" "HE WON'T DO A SKID" ahh peer pressure i love it.. it's not the burnout on the bridge that's got me worried Silver R34, it's the one under the bridge that got me cut, and a certain R34 spotted doing donuts it an open field.. :S
hey that grass field asked for it... look at me im just going to sit here and make funny faces at you.. wait no. ur tearing my face apart.....
mum and dad are getting annoyed with black lines leaving my street,,, u wont be allowed over for sunday roasts the way ur going
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
