shanef has taste.. that's all i can say!
He has a GTR - thats the definition of taste.
maybe :whistling:
sweet, so its tools out tonite and put them on? or r u not that keen and ull do it tomorrow?
Nah forget that - spun bearing, so ive got 2 new paperweights until i fix the motor
>_<
power fc, blitz ebc id III, fuel pump & clutch line arrive next week :whistling:...taking 2 weeks off work after next week to get the engine bay painted, and to get the engine on its way :D
spun bearings FTW!!! what did urs look like?
heres mine :whistling:
twas out of cylinder 2
Hahahaha, yeah, the only bad thing about an RB26 - bearings
Havnt pulled the motor out yet so im not sure >_<
Should be doing it next weekend though :D
ShaneF after going through the engine bay painting exercise be careful about the rubber seal round the ecu loom as if that is damaged it is a pain in the a$$ to get another one
thanks for the heads up mud, will make sure we dont damage that in ny way
all i can say is...HAVE FUN!!!
oh btw, be prepared for one of the engine mounts to get stuck, and if it does, dont just jack it up higher, caus they split in half :whistling:
Yeah, rods, crank, pistons, bearings. Also oil pump, headwork, cams, turbos
if your doing that much work, why not whack in an rb30 bottom end? then u can run bigger turbos, and not have it as laggy :whistling:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
