The lady in the seat next to me had the nerve to say to the hair dresser "You let Men in here"....
I turned to her and said "Oh darling you dont have to worry about me, Im Gay"...
It was really funny...
BTW... For those who dont know me, Im not Gay... Except that time with Bunta but that was for medical research...
that was meant to be a secret :blush:
Fark there is too many band wagons around this place!
At the start some one got a good tune from Matty Spry...then every one was on to him like fats kids on a birthday cake
Then I say I didnt choose him cause I heard some bad reports and now people are in a panic??
I chose Chiptorqe because people that I truseted suggested it...If Matt works for you why change that based on my personal opinion, and that didnt work out that well for me anyway!
And John why the hell do you need another tune...your car has been tuned more times than any car in the history of man kind
because recently the studs were replaced to which hardcore nicely told me one of the studs were missing when they took the manifold off. now that all studs are there (so hardcore have told me), it needs another tune from what dan explain to me the other day.
as well as the fact that the piece of shit is spiking. recently it's also been splattering alot for some unknown reason.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
