Well it doesnt 100% expalin the problem...it is worth investigaitng but, but yours has been playing up for weeks..so I would suggest it is somthing else, why would a car need retuning after having studs replaced?
according to hardcore when they replaced the 4 broken studs, a stud was also missing from the manifold. after talking to marc & dan about this, marc suggested a tune may be required. dan high suggested a tune to be done cause of the missing stud where the car was tuned without it and something about more or less air/gas.
fark R33skyliner... your car has been retuned more times than Jenna Jameson has been rooted on film!
i just got called in to work on my day off....
am now working 9:30pm - 5am
yay4me! :)
i've had 2 tunes by Brisbane Tuning. The other 3 have been done by Matt Spry.
I only had the most recent one done because I've had the z32 AFM fitted and to make sure it would last out on the track for track day back on 4th july.
Other times it's just been power runs on dyno days such as at Allstar that skyline thursday night we had and also a few weeks later on a saturday arvo for some special event they put on for the day.
The one coming up next Friday is because of as stated above.
Their just feedin u that so its not 'their fault' :)
If it happens next tank of fuel they said they would fix it free...so Meh I will see what happens
Is the whole car going to be that colour Shane?
Yeh eventually, need 2 more weeks off work, only got 1 more and gotta get the engine in and tuned, so will do it later in the year
but i recon the way it is now is good, it looks like a stock gtr from the outside...
It would be kinda weird but...Will be much better when it is all painted!
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
