afm? could be its not grounding properly, had the problem in my 33, could not figure it out
I thought it could be somthing to do with that too! As it is a new Z33 one, Can that cause misfiring and knocking as well but??
Some spork facts!
spork: a combination of a spoon and a fork
sporked: to be jabbed or prodded with one or more sporks
sporker: one who uses a spork for pleasure alone or for humourous reasons within a group.
sporking: a game involving a group of people with sporks who chase after fat kids, saying they will eat them.
sporkage: someone who has just been sporked by a group of rowdy sporkers.
sporkness: to resemble a spork
sporkification, sporkified: process and product of morphing into a spork
sporkage: that fatass just had some extreme hardcore sporkage back there by those rowdy sporkers
And on the 8th day, God decided that Adam and Eve needed a multipurpose silverware item. Thus, the spork, a combination of the prongede wrath of the fork and the carrying capacity of the spoon. Sporks are thought to be the most holiest of silverware. They are the only ones possible of freeing us from the evil clutches of the finger foods. There only weakness is that they can't stay outside after 12:00 on the night of the summer solstice.
Some spork facts!
sorry anna no time to read because ive limited my self, and i have to stop whoring at 12 so i only have 19 mins left
Some spork facts!
The internet is so chock full of useful information
Why don’t you get all of ur work done through Dan then?
I’ve done most of the work on the gtr expect the assembly of the engine (due to it having the rb30 and I wasn’t 100% confident I knew exactly what I was doing). I’ve called dan up numerous amounts of times to ask quick questions, and he’s been really helpful.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
