Yeah, was thinking the same thing about QR, but I got an absolute bargain today on semi-slicks for my stock rims. Brand new tyres, fitted for $108 per tyre!! They are probably shite, but at least I won't be flogging my good tyres anymore.
hmm so we know who to blame if its as bumpy as the old one!!
i thought that road was the deacon deviation or something?
we only design it, we've got nothing to do with how it is laid etc...that will be done by the contractor
home alone tonite ;)
ahh ok... still as the closest person to that bridge i for one will hold you personally responsible!!
home alone aswell... what to do what to do.. i cant drive anywhere unnecessary as my brakes are worn and making noises. Last time it happened in the cressida the pad fell out and the piston was rubbing against the rotor after a while
OK, to answer everyone, the Deagon Deviation is the part of the Gateway that goes to Redcliffe via the Houghton Highway over the Hornibrook Bridge.
The tyres were for my stock rims so they are 16"s
I also got two new tyres for my 18's as the Silverstone shite ones were down to the canvas after some "spirited" driving after Dinner on Wednesday night. They are Nexens and were $148 each and before anyone says they are cheap crap, I know but they were CHEAP and a few guys I trust are running them as well and have said they are pretty good. I will see, and if they aren't good enough, I will get two more Firestone Firehawks which I reckon are fantastic tyres.
Does anyone know where I can get prices on Bride seats, the GIAS recliner is the one I'm looking at as it will lower my seating position and allow me to wear my helmet at track days without banging my head on the roof and sitting awkwardly.
i've got nexens on the back of my car (265/35 18's - 220ea) and yes they really aren't a bad tyre once you get over the brand snobbery. Ok so they're no advans but for the price they're not bad..
no idea on the seat question dave.. i have a similar problem, last trackday i had to recline the seat back fully sik bro croozin spec so i had room
Evening Mike!!!!!! How is Jaime and the sprog??? Still bigger than his old man???
Yup, bubs is now 7960grams so he could take any of you tough guys on. If he could be bothered getting up and walking that is.
Oh, by the way, the new plates arrived on Wednesday and they are just as bad, if not worse than the first lot!! I rang Mud and we will wait until he gets his to do something about them.
PPQ are teh suxor!!!
I'm off to play AA for a couple of hours. Working all weekend!!
See you all at dinner next week!! I need opinions on the destination though as I have made a fairly risque suggestion......
whats this AA u speak of dave?
Dave, this post is for you. Found this whilst checking out nissansilva.com
http://www.nissansilvia.com/forums/index.p...howtopic=189649
Half way down are the Bride GIAS seats, not cheap at $1800 for red or $1850 for black. oh and then u need a rail, which is $240
Shit!! That is expencive!! Might have to try and find a barge-ass seat that is way cheaper!!
AA is Americas Army. Free to download but a BIG download and then you play online. Not bad for a game made by the US Army to recruit soldiers!!
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
