Daniel mate what's your shitty job?
I'm not really a big fan of Bathurst, i just dont get in to it but i do like going to see them live at the indy, just gotta love the sound of thoose big barstards.
OMG sif like the lame event at indy more than bathurst
HA HA HA
we have no idea of what we're going to do to them..... post-23079-1160111015.gif
yeahhhhhhh..but THEY dont know that :(
Im great at cake why is 3pm cake time??
because the company i work for puts on cake every friday :)
agreed...although there are more ladies at the indy :)
Lee i have to go through 4 and a half pages of stock items line by line and reprice them because they all have different discount structures, stupid bit is they are all made by the same manufacturer.
Only cake when its peeps b'days.....we have bbq lunch up here!!!!
drive each...hell if u drive mine im sure u'll be sold on it, then ull want the Rb30 :(
i mean for the amount ud save getting a 32, u could spend that on the bottom end and have that RB30 u've always been dreaming about
Yeah always had a soft spot for 32's they just have that "dont F%$K with me" type stance
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
