who are you going camping with??
Going down to SA skimboarding. Yes we are that serious. I think atm there is about 30ppl booked in. So should learn a lot, by the time I get back I should have worked it out how to skim the big stuff. That or I'll have a few broken bones as they are big arse waves. That or be eaten by Jaws. As parts of the movie were filmed only 1km down the road from where we are staying. Leave in 16 days! :wave:
argh ok. cool as, u gonna turn pro when u get back are ya lol
hey did u say u were comin up to moffat's on the weekend just gone,??
did u end up coming up....how was it....
Yeah were going to go to moffats, got the call that it was flat and to go to shellies. Went there and it was soooo windy. Even some of the kite boarders were struggleing. Stupid wind.
u should have went too coolum, the annual kite festival was on! guys were kite surfing and all.
hahaha im the only one in my fammily that dont get affected by it lol
but from how the complain, i would say it does suck
oh it does suck. but i never used to get it, but lately i have been getting it for some reason.
i have puffy eyes that are always irritate and i get sneezing attacks, its bullshit!
cheers guys,
shane , did he mention if he could tell any difference?
i dont want them for myself just curious as ive seen a fee cars with em
he said he can notice them, but not like a big difference...he said the main thing he notices is a bit more front end grip, due to more front end downforce and better aero drag
Morning whores!! I'm off to golf and then tennis and then work!! Feel sorry for me for that last bit!! But then I don't go back to work until the weekend!! 2 weeks until holidays!!!!!!
jeez dave, tennis, golf, lazy days.... seems like retirement to me! :D
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
