warning- the number boost setting displayed does not represent actual boost, it is a percentGE ratio. O represents stock boost, 100 represents maximum turbo charger capabilities. hmmm straight forward i guess.
well set it low, go for a drive and see what boost it actually makes. and then just adjust it from there
32 gtr turbos only make 18psi MAX (wastegates disconnected)...so u could say gts-t turbos would be similar, so for say 10psi ud need a percentage of 55%, but set it at like 30% and see what it actually makes
i got it set to 40% i think.. (havent driven in a while) and im just worried it might be a little to high, as the standard boost guage on the centre consol, the arrow hits 1bar (guessing) and stays there :S being as one bar is a little too high for my standard gtt turbo :S, i tihkn i mgiht turn it down
i called three different places today, and was quoted between 1100 bucks and 1500 bucks for a full 3 inch system. does this seem right?
yep it does..where they brand name jap ones?
no, they were just shop made i guess. whcih is why im asking, as brand ones seem to be cheaper, well form auto barn and other sites
oh, well i guess thr shop is including the install fee
full turbo back systems arent cheap.
do you want a stainless exhuast or mild steel one??
also look in the forsale section there is some traders who are selling "catco catalytic high flow 3" cats". get one of them, they are a must for the best flow possible. and are a very good cat..
also if u arent phased on the name of the system x force selling systems on ebay for $675 i think butu only mild steel. they can weld stainless to mild aswell.
what is the difference between stainless and mild steel...(please no smart ass replies) i mean, do they each give different performance/sound? or is it simply a finsih
or look at this one if u are interested. not a bad price.....
http://cgi.ebay.com.au/R34-GT-T-3-Catback-...1QQcmdZViewItem
thanks daz for taking the time to search for me :P
stainless wont rust, whereas with mild steel, if the car sits and water sits on the steel, rust will occur...also the note is different between them
Cost man. From what I have read if you think you will keep your exaust for more than 5 years go stainless, if not dont waste the money just go for mild steel. Really all it is, is a waste pipe...
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
