Cool!!
sik days daveo!
Damn cars
Who wants to come over an tell me engine is screwed...just so I am sure lol
It's screwed. Buy new one from aaron, and donate old one to me. kthnx
Thanks Dave for the offer but I can't really justify the cost for Regatta...you guys go and have a great time :O
:laugh: weak++
thats not so noice...why do u think the engine is gone?
Metallic flake is cool for paint.....but no so for engine oil
sik days daveo!
:laugh: weak++
deal is done
deal is done
oooh man that sucks! has it begin it's death rattle?
well that made ur decision about the new engine easy didnt it :laugh:
Do you need a lift Andrew?? Or is this a slow death we are talking about??
And Karen, I owe you and Mark still for that Friday night you came to my rescue, so if I buy you lunch at the Regatta, I will feel better???
deal is done
LOL it's been getting rattlier (sp?) for a couple weeks now. Hehehe. It actually started to make noice like something was flappy around.
nah no real death rattle yet , there is a slight ticking today
And Karen, I owe you and Mark still for that Friday night you came to my rescue, so if I buy you lunch at the Regatta, I will feel better??? v
I should be right for a ride there! I just have to plug the AFM back in ...if I get lazy or can get the airbox on in time I migh run Jap style filtration! But thanks anyway Dave!
any idea as to what may have killed it?
the old turbo had busted seals
This cause oil use
I was unaware of this problem until one day I almost ran it dry
My theory is the constant oil problems destroyed it slowly
I'll be taking bets...starters at $50 that it wont be in by sunday
:laugh:
OK you are on
This guy can take out a GTST engine in about an hour
That leaves the rest of the day to get it back in
They did a GTR in a day ad it was harder cause of the 4wd
OK you are on
yeh they dont take that long, just fiddly that's all
gtr's are a pain, gotta pop the front right CV and sometimes they aren't all that forth coming :laugh:
Dude thats not very nice....$65
lmfao :O
morning daniel
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
