Morning Cy, morning Shane!! What a wonderful weekend!! Football Saturday where we beat the top team in the League!! Partied Saturday night which may or may not have been the cause of my sick day Sunday. This allowed me to attend the photoshoot which was great, met some new people and then went bowling and scored a HUGE first game to absolutely blow the competition away!! Haven't bowled in over 10 years!! Got a 174 in the first game!!
Slept in this morning and got up at 10.45 and watched the new Gridiron movie with the Rock starring!!
Now I am going to go and play tennis and tonight I play in my first Poker tournament.
Hello bitches!!
I hope you all had a great week end.
Man i wanted to go bowling but after what we did on sat night i was asleep by 7:30 Sunday night
he he he
Spent the weekend at the coast swam all day on sat, at the beach and at the resorts pool i was staying out, then partied all night sat no sleep then off to marina miarage at 5 for some FISHING!! but OMG it was so choppy of there most of my buddies were huggin the railings :) was a slow day out there but i still caught a few fish, I thought i was going to be fine but the i got :) and puked as well :) OMG the swell out there was huge!!!
man cam home and the ground was still rocking!!
he he he
:wave:
so its a button clutch then? i had one in the 33, which i killed as at that time i didnt know i needed to bed it in and i went to the drags and guess what, the next day it was slipping like a mofo :wave:
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
