Yeh a clicky here and a clicky there (30 seconds later) did fark all :no:
who wants to wait 5 mins between shots.... :thumbsup:
It was particularly bad when the nurses would come and give you some notice that they were coming to change the bed sheets so click click 5 minutes later they turn up and roll you over to change the sheet and you just want to rip the farking heads of cause it hurts so farking much. After about the 4th or 5th day and the pain is starting to subside its not so bad. And this was when i was only 12 or 13.
Not very I wouldn't think...plenty of after market suppliers plus wrecker yards :thumbsup:
The seller may even have the wing...he may have just taken it off for a different look
Off to lunch now...BBL
would like a genuine one if i could get one.
Dont mind the type 2 as its not to big.
One other thing that it will get is a carbon bonnet....really like the eastbear one
Guy on teh forums here is called MrVSpec...he works at Custom Carbon :no:
His car is awesome BTW...lots of nice carbon bits here and there :thumbsup:
I just know it is a good car and has been recently rebuilt...I am actually trying to help you but *shrugs shoulders*
Its all good man, i appreciate the help. The thing that worries me about it is those god damn tri spokes......lol. Do you know if the minor accident damage has been repaired?
The reason I asked about 4ZzZ was it reminds me of JJJ before they went all political correctness and generally began to suck big time, so it's been around a long time, must be the new location I'm working in (Kenmore) because I've never tuned it in before.
There was no actual accident ie panel damage if thats what you mean... :spank:
Those tri-spokes are worth quite a bit...but like paint, can be changed very easily :P
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
