Yeh a clicky here and a clicky there (30 seconds later) did fark all :no:
who wants to wait 5 mins between shots.... :thumbsup:
It was particularly bad when the nurses would come and give you some notice that they were coming to change the bed sheets so click click 5 minutes later they turn up and roll you over to change the sheet and you just want to rip the farking heads of cause it hurts so farking much. After about the 4th or 5th day and the pain is starting to subside its not so bad. And this was when i was only 12 or 13.
Not very I wouldn't think...plenty of after market suppliers plus wrecker yards :thumbsup:
The seller may even have the wing...he may have just taken it off for a different look
Off to lunch now...BBL
would like a genuine one if i could get one.
Dont mind the type 2 as its not to big.
One other thing that it will get is a carbon bonnet....really like the eastbear one
Guy on teh forums here is called MrVSpec...he works at Custom Carbon :no:
His car is awesome BTW...lots of nice carbon bits here and there :thumbsup:
I just know it is a good car and has been recently rebuilt...I am actually trying to help you but *shrugs shoulders*
Its all good man, i appreciate the help. The thing that worries me about it is those god damn tri spokes......lol. Do you know if the minor accident damage has been repaired?
The reason I asked about 4ZzZ was it reminds me of JJJ before they went all political correctness and generally began to suck big time, so it's been around a long time, must be the new location I'm working in (Kenmore) because I've never tuned it in before.
There was no actual accident ie panel damage if thats what you mean... :spank:
Those tri-spokes are worth quite a bit...but like paint, can be changed very easily :P
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
