already had one of them
over them the week i had it.
never again!
well your choice....
i've driven my bros skyline before not bad....
Its all a matter of prefreance.........
any way.......
talking about my bro.......
Karen he's not gonna be able to pay for a few weeks yet....
Burnt out his cluch so its now down a Ivan's shop (cant rember the name of the shop but its down near Moss street, he's an importer but also does some fitting,) getting a new brass button and lightend fly wheel, cost him $900 so has no money for the next 3 weeks :(
HA HA HA
there is a major storm on its way and damm its gettin dark already here in the cbd.
however, hopin that the miss indy finals outlay is as follows -
stage contains no roof or cover for the girls to strut their gear on.
the seating area of guest/patrons contains a roof/cover.
therefore, girls getting wet *ohhhhh yeh!!!!!* and patrons/guest (thats me) remain dry.
what a schweet idea!
be prepared to listen to his whinging about that button clutch :(
but that's a pretty awesome price lee! my clutch alone was more than that! :)
i need to order a new clutch soon,
he he he asking dan to do a rebuild soon and thought i should do the cluch as well while the engins out,
but i dont know what to chose,
which one do you reckon?
http://www.nissansilvia.com/forums/5-Butto...33-t121382.html
I'd go the street clutch....unless you like going to the chiro to keep getting your neck put back in.
Hey Shane you going to have you R back on the road for the annual cruise?
who knows. depends when it is.
seeing as ur going rebuild, get urself a decent clutch:
Jim Berry
3847 9999
I got his 'Full Monty' which is his top of the line clutch and its rated at 1000+HP, but u wont need anything near that.
but there's only like a $90 diffrence
he he he
but yeah Linh wont eva be able to drive it again if i get the button,
and organic is just like the ones we have in our car normally right?
You might find that the pressure plate with that more expensive kit is only rated to 1050kg (2315lb) and it might give a light pedal feel still, as it's not very heavy. How ever, with a low rated pressure plate & aggressive clutch face (button), you wont get the same clamp force as with a heavier pressure plate with a tamer clutch face (organic mix). My clutch has a 1633kg (3600lb) pressure plate with a carbotics (carbon, steel & others mix).
Give jim a ring and have a yarn with him.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
