OMG you gotta be kidding me... how long did it take? oh well Hello to you....
hours lol skipped through it tho i wasnt sitting there fully taking it all in lol just skipping through with my eyes
no job = time on my hands lol
Edited by raZ1911
a friend of mine is interested in getting them, do you know a website or something that he can look at?>
they are actually M's pods (i edited the post hehe), but i havnt seen any sites that sell them brand new. only ones i know of are the apexi ones. but i have seen some second hand
i'll have a squizz now for ya
A new one at Sunnybank, down mains road near the caltex....
there's meant to be a better all you can eat one near the Mater Hospital thats even better and only $20 a person
might have to see if anyone's up for it for a Tuesday night dinner....
:P
The one near the hospital is Bens...It is good :(
ahwell, u still would have had to gotten out to ipswich somehow.
nah man i could just lend ya my card and then you reap the benifits :P
he he he
Have done this many times,
i tow my baby to the mechanic often and all my other friends cars.
he he he i always tow my dad's delivery trucks when they brake down......
yeah its the one next to Ben's, Beewon,
hmmm.......
might have to give Karen the Details.......
but i know one of the drive ways there isn't "Skyline Friendly"
he he he
yeh i can, but it depends on what type of document it is. Like with that sort of magnification, its more than likely to come out pixelated
alright well i\'ll make it in A3 size... that should be a bit better...
alright well i\\\'ll make it in A3 size... that should be a bit better...
actually... i\'ve made it 40.32 cm x 55.83 cm, that\'s as big as word will let me do it, so just increase it by like, 40% or something...
ok, send it through
afternoon all :laugh:
w00t for 1 hour of mindless training drivel delivered by 2 people who really didn't understand what they were even talking about themselves...:P
In the end, was referred to a document which someone else wrote anyway :(
did u make fun of them? :(
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
