Btw.
Toyota Prius pwnes any Rb26. EVA
lol, i think that's the funniest thing i've ever heard
let me guess, u own a prius? oh oh is it bright pink to? with pink trim and seatcovers, just like lees??? maybe the 2 of u can get together sometime :rolleyes:
nyways bed for me, laterz :P
let me guess, u own a prius? oh oh is it bright pink to? with pink trim and seatcovers, just like lees??? maybe the 2 of u can get together sometime :D
nyways bed for me, laterz :)
RB = Reliably broken
hmmmm...........
Shane you cheap ass......
sif take cheap shots at me while i'm not even here to defend my self..............
oh........
Morning Bitches.....
Yeah!!! Auto Salon this week end!!! See you Bitcfhes on Sunday!!!
as if i'm gonna waste a good oportunity to pay u out just caus ur not there :D
i'll make an appearance on the weekend, dunno which day yet, going out to dinner sat, got house warming sunday arvo
OMG!!!
Its like.........
Dead I here.......
Its So Quiet........
You could hear a Mouse Fart!!!!!
IT's Friday!!!!
Week end!!!!
BRISBANE AUTO SALON!!!!
MISS AUTO SALON!!!!!!!!! :(
Week end!!!!
sloooowwww down!
its only brisbane autosalon dude.
nothing special about this thing.
its all to over rated and hyped up for nothing.
seriously, each year it just gets worse and worse.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
