i dont do wat you do to 14yr olds. get it right.
or even better yet, i dont meet girls and offer to fix there car and then in exchange ask for sex.
thats right, you deni all that yet, mods on cruisingbrisbane have pm's and logs of it all.
hence why your banned not once, not twice by 3 TIMES!!!! under different nicknames for the abuse, threats, harassement, etc.
btw, if i was you eddy, i wouldnt go out cruising all that often. a few of the guys on cruisingbrisbane would like to meet up with you. one i wouldnt want to get in the way of, thats for sure!
hmm quite a story that. MEL504 owes me $$ for the gearbox and the labour. no sex was exchanged for the work i did on that heap of shit
14yo girls? like who. the ones who come out of ur house saying "what a stooge, cock the size of a tic tac"?
john or any of u other tossers for that matter... if u wanna say something about me, since the fact none of you know me.. get my mobile number off me, come say hi to me tonight, im 100% sure none of u cockface gerbals will say a word to me, especially u Mr speach impediment John... there are a few members on CB (namely the one in my sig) who want to take u into a back street and flog ur head in for the simple fact u dont not know how to respect a girl, nor can u lie straight in bed, u may have everyone fooled around here but every dog gets there day and urs is coming soon my friend.
Edited by EnGaGe
:verymad: NOW SEE HERE YOU LITTLE SHIT !!!!! WHERE ARE YOU GONNA BE TONIGHT I"M GONNA BREAK BOTH OF YOUR LEGS.
THIS IS NO JOKE!! I'M GOING TO FCUKEN BASH YOUR LITTLE HEAD IN
I CANT BELIVE YOU BRING RACE INTO THISS
I WILL SEE YOU TONIGHT I WILL FIND YOU AND I AINT TO KEYBORAD WARROR HERE
I AM GOING BREAK BOTH YOUR LEGS AND ARMS
hahaha caps lock is located to the left of the "A" key
for the sake of this post... i'm quoting you on here for that nice little bullshit threat.
in other terms... f**k off where u belong in one.
you've done absolutely nothing but create enimies everywhere on every forum your participated on.
so do yourself a f**kin favour, go get yourself into rehab and get a reality check, dipshit.
mil keys ftw! hey john :sick:
p.s i do believe, parent company being an american, if anything were to happen to any of their employees, shit would really hit the fan then :verymad:
hell yeah! the americans dont take lightly to their employees being threaten, abused, harassed, assulted or any of the kind.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
