Guess how much I have spent....you will hate me
nah no quarter mile time yet, I have had it since Feb this year....and been replacing stuff and trying to get ti to run properly since July :happy: lol
try finding someone to tune an FCONV...it doesnt happen in qld...so I used to have to contend with an extremely anoying idle and some very rich afr's. I believe that Matty Spry might have the software now though.
that's easily fixed, bust out the scissors, cut Mr HKS off and wire in Mr MOTEC :happy:
no idea... 20K?
And for the record that 13,250 is how much the car cost me btw :happy:
All ive changed is fluids :P
Ahhh I see in that case you are doing better than me :P
It would be good if he did have it! They are an awesome computer
With the 3037s what was the boost response like?
was going to but never got around to it and eventually sold the car.....to tempting. I need my license and it was annoying to go driving and worry about the police pulling me over for a check and going, excuse me sir but why does that screamer pipe vent into the atmosphere? (amongst otherthings) Im going to wait and have 2 cars, one for track and one for the street. Its a much better and safer equation. I do miss the fun though..alot!
money wise maybe - performance wise not :happy:
im not a childrens anymore though :P
have to make house payments now so cant just willy nilly buy things
am EXTREMELY happy with my car though! skylines are sooo cool!
Ahhh I see in that case you are doing better than me :happy:
It was good for a turbo of its size, I had cams which aided it, but it came on around the 3800-4000 mark at 1bar.
You will be first on the list Anna!
Hey when do you need the mone for the NYE thing. Looks like there will be 2 of us
sik sik subw00fa!
Money anytime mate, I just need to know if you're a DEFINATE. Including you 2, there are 8 definates. So I only need 2 more to get the discount :happy:
your right about the fconv too, they are an awesome computer...just very hard to tune being they are in japanese and almost noone in aust has the software. Other than that they have so many features and allow an amazing tune. My car had been tuned by garage saurus in japan but they must have made the map a lot richer when the car was sold because the afr's were a joke when it was dyno'd at millenium.
money wise maybe - performance wise not :)
im not a childrens anymore though :)
I have spent under 15k on mods...so I guess I am still doing ok!
Hmmm thats not toooo bad *ponders*
got ny idea what the 3037 garrett equivalent is?
you mean price wise or what the difference in boost response etc is? Garrett make HKS turbos and they also make a 3037...the difference is the wheels, HKS put different wheels in their turbos to make them respond faster and smoother etc etc...But Garrett turbos are cheaper than HKS, so i guess you way up the options.
Edited by 33NIZ
A GT30 somthing?
But I bet it isnt as good :)
Its nowhere near as good, almost all HKS turbos have an equivelant Garrett turbo being that they are both made the same. But there is a big difference in response and overall peformance. I have been in cars with the exact same turbos, HKS and Garrett versions. You notice the difference.
no no i mean wats the equivalent turbo in the garrett range i.e 3040R
A GT30 somthing?
HKS only come into their own with hi boost and big rpm, otherwise the garretts are just as good. and quite frankly, if u want to pay the extra couple grand for the 'better' hks then go ahead :)
dude that's rubbish. there have been people test each turbo on the exact same motor, and the only difference they noticed was the HKS provided marginally better performance at higher than normal boost (2bar+) and high rpm
sik sik subw00fa!
Money anytime mate, I just need to know if you're a DEFINATE. Including you 2, there are 8 definates. So I only need 2 more to get the discount :)
Cheers will have and a talk to the girl tonight and make it definate.
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
