No way! The best time of my life was about a year ago when my diet consisted only of coles brand rice bubbles and diet lemonade. I ate only coles brand rice bubbles and diet lemonade for 2 weeks straight. It was so tasty! But I must admit it was good to get back to normal food :woot:
sorry guys went out for lunch....
john i'm unsure about the laws but i think its fine as long as ya wheels dont stick out past the guard end..
prices for something like that hmm i dunno really, depends who fabricates it really...
and anna yeah that blue 33 is the nicest widebody i've seen in ages and thats what i want HLUCN8 to look like.
Nah. She doesn't really have that many friends. I just feel bad for her because my mum wants her to do uni by correspondence. My dad doesn't want her to do uni at all. He is of the old school belief that disabled people are destined to sit at home and crochet rugs, or bake cookies for the endeavour foundation. Which is exactly what he wants her to do. I reckon she needs to get the hell outta there and go to uni.
Then she asked me if I was going home for Christmas, and I said no, and explained why (we spent the last 2 christmases with my family, and andy's family missed out, so I think it's only fair this year, we go to his mum's place for christmas). She didn't like it, got the shits and said 'fine' then blocked me. Little wench :woot:
Bake cookies and make rugs? My opinion is that is more for people that are mentally impared. Tell her to do what she wants to do.
noy.... so would it just be possible to take my car to a body kit shop or somethin like dmd and say "hey, this is the wide end i want dont with mine, can you's do it using my gaurds" etc?
yeah just show em a pic and they go from there.. any fibreglass shop should be able to do it mate...
LOL yep definately sounds like she's ur sister :woot:
LOL shhhh
Anna. was that rice bubbles with lemonade instead of milk?
my weekend sucked, work sucked
but i got Guitar HEro 2 yay
no no the rice bubbles were just plain. No milk. So crunchy. And they'd stick to the roof of your mouth :wub:
Not a fan of the guitar hero game... I prefer my singstar & dance mat :laugh:
oh and here's a night shot of it anna... looks good..
oo00o0o000o very perrrdy!
1 thing id suggest if u get it done john, make sure U keep all of the moulds that they make, because ur the one paying for it all and if they want to keep them to reproduce later, charge them for it
ah. but still, when you have two people, holidng the little plastic guitats and jumping around etc, its kinda like the dance matt, lol, just without the dancing.
yeah dont really like the vent in the rear but that wide looks good not too wide but PHAT.
yeah, im sure i saw this car in person at the 2005 MSC, could be mistaken though, looks awesome from the back to,, i will see if i still got the pics.
there is actually a thread in the QLD sectyion a while back when someone asked about buying trhe kit, and theres a few videos of it, anyway would lovet o see the end result.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
