I just had a meeting with my supervisor about 'work levels'.
It's too hard to explain the shit i've been doing this past week, but basically I get a file on a school, and there is a lenghty process I have to work my way through until the file is completed. Today, I completed 84 schools. My colleague, sitting right behind me, completed 4. How the hell can someone who sits on msn and SAU all day whoring, complete 84, and another who seems to be working flat out all farking day, complete 4... it's rediculous. So I called a meeting to complain. And I sighted the example I just gave you folks then. The fact that I chat to friends all day, and I can get that amount done, and she does nothing. So yeh, she's in there now getting in trouble. YESSSSS! She's the one i've been wanting to push down the stairs for the last 3 months. Hopefully this incident will stop them from making her a permanent :wave:
It's too hard to explain the shit i've been doing this past week, but basically I get a file on a school, and there is a lenghty process I have to work my way through until the file is completed. Today, I completed 84 schools. My colleague, sitting right behind me, completed 4. How the hell can someone who sits on msn and SAU all day whoring, complete 84, and another who seems to be working flat out all farking day, complete 4... it's rediculous. So I called a meeting to complain. And I sighted the example I just gave you folks then. The fact that I chat to friends all day, and I can get that amount done, and she does nothing. So yeh, she's in there now getting in trouble. YESSSSS! She's the one i've been wanting to push down the stairs for the last 3 months. Hopefully this incident will stop them from making her a permanent :blink:
bahaha u eveil, evil person...i like it! :wave:
I know, I know. Well she shits me, and she smells, and I really really do want to shove her down the stairs... but I guess this is the closest i'll get to shoving her out the door :wave:
See joo soon shane.
See joo soon shane.
Smelly poo poo!!!!
What a shitfull day tomorrow better be better than today
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
