Question for a technicla person should they see this...or maybe a research project for bored people
HKS 2835 with the .63 housing
Garrett GT30R with the .63 housing
What is the difference is spool up times going to be?
ill dig up some compressor & turbine maps :huh:
Based on that scientific advice I will thke the GT30 :huh:
Then run it at 20psi and see what I make!....apart from brown undies lol
i was just gonna ask how much boost u looking to run in it? Also wats ur rev limiter?
GT3071R-700382-3
Compressor -
IND - 53.1mm
EXD - 71.0mm
Trim - 56
A/R - 0.50
Turbine -
Wh Dia - 56.5mm
Trim 84
A/R - 0.64
HKS 2835
Compressor -
IND - 51.2mm
EXD - 71mm
Trim - 52
Housing - GT35
CFM - 608 MAX
Turbine -
Trim - GT28
EXD - 51.8mm
IND - 56.5mm
Flange - T25
Housing - 0.61 or 0.73
The HKS info was taken from this site: http://www.ztechz.net/id1.html
From that info id have to say the 2835 would be slighter better. Having a smaller comrpessor wheel aids in spooltime, but i dont know how the Trim affects things. Also given the fact that HKS turbo's are 'known' to perform better at their peak (read effiiency) id go for the 2835, thats if u dont mind spending 3k on a turbo :huh:. Also i dont know if that HKS info is actually 100% accurate, as the site it came from isnt a 'genuine hks site' so it could be out.
Also, i think the best way to go about choosing a new turbo, would be to have a power figure in mind, boost level u want to run, and then u can work out ur flow and then by looking at turbo maps (compressor & turbine) u can correctly choose the best turbo for ur application :huh:
Actually, bugger it, ill make a phone call and get some definate info, as i need to figure out what turbos i can run.
20-25psi and lets be safe and say 8000
hey andy.....
i remembered you said somethin about not bein able to replace it till friday if we didnt do it the other night.
can come around tonight before i make my way to shanes????
You can come and pick it up tonight and swap it yourself and bring the black one back later? Cause I def wont be home tonight
20psi for about 260-280 rwkw Would be ideal I guess
That will be nearly at its limit if you get 280atrw.
it'd be past its 'limit' with a 20% drivetrain loss at 280rwkw. But it'd be good for 260rwkw. A turbo is best run at its 'peak' so u get the most out of it. I'd need to do some calcs and then look at some compressor maps, and i dont really have the time now. I'll have a play at lunch though.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
