Yeah it looks kinda blue in that pic but it isnt! It has been a while since I saw Johns but it was white almost a creamy kinda colour in real life, I am sure John can jump in here and confirm for me :P
And yeah you are kinda colour blind cause the pic I posted has a blue tinge...yours is like full on blue
Yeah it looks kinda blue in that pic but it isnt! It has been a while since I saw Johns but it was white almost a creamy kinda colour in real life, I am sure John can jump in here and confirm for me ;)
really? mines full blue? it looks white.. :wub: weird..
well let me know if u want my silver one or not, doesnt really bother me.. :P
Says the guy who likes exhausts because they are loud
Tell me then what was your motive behind buying the ID3?
not loud loud, sheesh
a few factors. first off i had an avcr in the 33, and i wasnt happy how it 'holded' boost or ramped up, it just wasnt good enough. and also i went and visited paul & stacey diemar (who run TWOOGLE) and they went from the avcr to the ID3 and gained power everywhere! just by changing the boost controller. also the ID3 ramps up faster, and holds boost solid all the way to redline. plus the ID3 shows boost in psi & bar :P
What??? You are the juggenart (sp) ?
ahahahah nope! I am coming to visit in a couple weeks. I miss it so much, I just can't keep away!
u were able to get them 'skidmarks' out? :P
ahah nope! That skirt is history!
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
