yes, I do believe they always remove the bonnet when they install a new engine :laugh: lol
lolz. you are part of a million teams now! team trashed @ trackdays... team13... team New Engine! WOW! :(
yes that is Liz
this is also Liz
lol.. *sigh* hahahahahahahahahahahahahahahahahahaahahahaha
(haha you thought i was going to do a steve then didn't you!!!)
hi sammeh! :laugh:
i'm about to head to bed, but it's 0400 641 593. Ta.
Oh jeebus... Enjoy death! :P
tis ok.. it's all over NSW
there is another rather disturbing pic
OMG IS THAT COL ON THE RIGHT
yeah, we were stuck with him.. i mean ... we took him to dinner last night.
ah, i understand now lol. was wondering lol
Hmm similiar kit to what i bought.
lol.
team silvia, team s13, team trackday, TEAM WANG, hmmm so many teams.
night anna!
:( Wow look at those tyres sticking out :laugh:
fateeeeeez!
b ahahahaahah hi anna bye anna
EEK! I can't leave. I am sad. Sad like scuba steve. *sigh*
in the pics above anna, ya calendar on the wall is outta DATE. :P and is that a pink skyline on your computer?
I know, I realised that after i'd taken the pic. Nearly a whole MONTH outta date!!! And it's an RX7.
fateeeeeez!
haha *sigh*
ok back to nsw!
night anna
bye QLD
ah, work is farken shite tonight.
customers going off their brains about stuff, airconditioning not working, customers whinging, am here by myself, customers being pains in the arse, flat out.....
did i mention i'm sick of the customers tonight?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
