Wow sambo on the left looks like he is having a great time
Morning all
let the wang pic die!
too bad its a ghey SR in there :P
TEAM GHEY? :)
morning whorebags & toerags :wave:
I'm glad I stuck to my guns and went with the sr
But i will miss the nice note of my old rb :)
She perfers not to have an extra 150kgs hanging over the front axle
with only 1100kg to pull (Stripped out) the SR will have more than enough power for her needs and have better bottom end than most RBs anyway!
Morning
yup.. and the vct means the top end ain't exactly shameful either.
And they'll be too small!!!! :P:)
500hp will do until march :wave:
Ang on
What are the turbos that were on it when I was there the other day?
they were std R34 turbos (ball bearing but ceramic wheels)
these turbos i just bought form a mate at work, are from an R34 NUR (ball bearing, steel wheels & shaft), and have ~100km's on them (yes u heard right) , also bought the HKS dumps that are on them aswell :)
Why not sell both sets and buy somthing good now?
caus with the next set i'm doing headwork & cams aswell (to match the turbo's), which will cost a fair bit, plus im not 100% sure what i want to set the car up for
I think i might keep my 31 and put it in the shed for a while......Then do to it what i always wanted to.....rb 26/30 with 600hp BB turbo 25 box and shitloads of rear tyres :wave:
and 20k later ud have a real weapon! :)
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
