hahaha.. yeah you were!!!! You were before aswell.. but I bit my lip lol.
*fixes hair* heeeyyyy lol
you, slider and I can have silvia wars!!! apart from his has aids so don't go too close
sounds awesome!!!!
Bunta - make sure this dude comes out with us when I go up there next!
u wont want to meet lee, he's a bad bad person ;)
Indeedy, My tyres alone are woth about 2 seconds, then I have suspension and about 80rwkw more...and I only beat you by a second to a second and a half (Cant remember) You are faster than me for sure!
Lies
*Evidence* ^^^
sounds awesome!!!!
Lee doesnt even own a car
u wont want to meet lee, he's a bad bad person :no:
;) STFU Shane!! :huh:
ha ha ha
I am the Key Board Ninja!!
Fear my Wrath!!!
:laugh:
I would love to come out to meet every!! :P i get my licence back next Wednesday!!! :)
*Evidence* ^^^
that's not the only instance I was talking about!!!!
ha ha ha
Fear my Wrath!!!
:laugh:
:no:
I'm heart broken!!!
;):huh:
Squeez me? :P
:laugh:
what is he even talkin about!
bunta.. you are being a cocky little bastard today "he doesn't even own a car" whilst you think to myself... "hahaha I'm so good, I have 2 CARS!"
lol.
lol.
hopefully not for too much longer hope fully one will be mine.
;):huh:
Squeez me? :)
:P
Well I have never seen it :no:
:O
I'm heart broken!!!
You KNOW that I dont think I am better than you, I am your biggest supporter always
lol.
You had to wait for the follow up joke and now you ruined it :laugh:
:huh:
I'm heart broken!!!
sorry Liz but y are you heart broken??
the Key board ninja was sumthing that happend a few weeks back.....
i was dubbed "the Keyboard Ninja" by sum wanker.....
OH i think i get what Andy's trying to say......
wit the new suspention and new clutch and fly wheel combo i think i need to get out to do some track work soon...
then we'll see who reaches for the excuses book first ha ha ha ;)
Well I have never seen it :huh:
You had to wait for the follow up joke and now you ruined it ;)
Forget it, she's in another one of her foul moods.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
