slide highflow, no idea on how long but probably not that much long... they said they had to 'modify' the wastegate actuator (ie bend it) so it would shut the wastegate fully, maybe thats still a problem, is it really that bad?
It isnt thaaaat bad (Well it kinda is)
My turbo was heaps laggy for a little while then it loosened up and came much better
yeah i'm doing that now,
driving it it actually sits on 8psi for some reason before continuing onto full boost, doesnt swing right round like it should?
What boost controller are you using? they can help lag to a degree
In any case you need injectors before you can do anything as they are out of flow at about 200rwkw...not mercury 200rwkw real 200rwkw :laugh:
its funny you say that andy as the more i drove it tonight the better it seemed to be, the turbo did sit for a couple of weeks before it got installed so maybe that was something to consider too?
i just thought that they are supposed to make full boost before 4000rpm.
and yeah yeah, the sheet still says 200 something so im happy :) althought the injectors are out of puff :laugh:
i used to have a turbotech one but they said it wasnt holding boost (although was working fine when i drove the car over to them?) but i got them to show me the dyno data which proved it, so now it has a simple gfb bleed valve conrolling boost.
They also had problems with the wastegate actuator (the one on the highflow was stuffed) so they swapped over my old one but had to bend it to make the wastgate function properly? wierd... hmmm
shane do you have msn?
certianly do [email protected]
having a dodgey ass bleed valve controlling boost and expecting it to be 'good' i should come over there and slap u myself :) get a real boost controller i.e Blitz ID3
Yeah when I put mine on it didnt get full boost till 4700 it had been sitting a year...now it can do 1.3 bar by 3300
ur budget is probably alot more than mine, real world example would be comparing nasa space program with indias space program :laugh: (yes i am india!)
having a dodgey ass bleed valve controlling boost and expecting it to be 'good' i should come over there and slap u myself :laugh: get a real boost controller i.e Blitz ID3
Most cases I have seen show the turbotech holding boost pretty well, what more do you want?? Oh wait the pretty screen :) Seriously for medium boost levels a bleed shouldnt be causing too many problems
shane is right, you cant expect to get decent or consistent boost out of a dodgy bleed valve, even cheaper electronic boost controllers will do a much much better job. Go to www.nengun.com and find yourslef a new one asap!
pffft as if, y do u think i do everything myself? if i paid a worshop to do all my work i wouldnt be ablke to afford to do what im doing
Most cases I have seen show the turbotech holding boost pretty well, what more do you want?? Oh wait the pretty screen :laugh: Seriously for medium boost levels a bleed shouldnt be causing too many problems
well alot of people use them no problem, i'm only running 13psi it should be able to handle that
says the man with an avcr :laugh:
now bed bye :)
later :)
i've seen cases of a screw in a piece of vaccum hose hold boost o.k on higher hp cars but still....an ebc can do more than give you a pretty screen, not to mention safety side of things. I remember when i was driving my car one day my ebc came up with a warning and wouldnt let me boost over .7bar because a vaccum hose had come lose and if i hadn't had an ebc I wouldnt have had that function. It could have saved me running unlimited boost and a lot of money.
yea it should but ebc's arent that expensive and if anything at least you have piece of mind, plus you can change and monitor boost levels from the cabin.
no but cost of parts alone i would say would easily be double my whole cars budget?
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
