Dan reckons to get an 040 to work properly there is a few tricks to it...I guess not everyone knows the tricks
I have seen a few cars that dont pick up fuel properly once you get below 1/4 of a tank...and somthing happened to Liz's 040 on her R33 but I cant remember what that problem was
i did my 044 in-tank, tad of stuffing around but was easy enough...depends on how it goes, i mite need to run a direct power feed to it...
Hey Michelle :)
shuddup John :P
:blink:
should i wear protection? lol
u have a wang? :O
plus the 040's r not a straight fit.
some adjustments need to be done.
dan did the install for my 040.
not suppose to run it below 1/4 of a tank but i've done it a few times already and car is and pump is still in excellent condition.
Thats heaps gay, mine is below that permanantly lol
What power level is a GTR pump good for people? It has slipped my mind
:blink:I GOT MY LICENCE BACK!!!
040 FTW!!!
just bought a new on for the sil $125!!!
cant wait till all the parts go into the car and its Tuned!!
oh and Good After noon Peoples...
040 FTW!!!
How do you know it is FTW if you havnt installed it yet?
id laugh if it doesnt flow enough fuel :blink:
yeh, i think i'm glad i just handed mine back in then :O
agreed *runs to police station*
The people who installed my fuel pump didn't modify the bracket that the stock one sat in, so it was flying around in the fuel tank (idiots)... it also didn't have the sock on the end of it causing it to become blocked.
A combo of no sock and flying around in the fuel tank is what I think caused my pump to fail.
I have never seen worse workmanship than what i saw when the bosch 040 was taking out of my 33... there was disintegrated hosing floating in the fuel tank aswell!
:blink:
u have a wang? :)
she's my wang sista!
:OI GOT MY LICENCE BACK!!!
040 FTW!!!
i'm sure the 040 will be fine if it's installed properly!!!
I just put a gtr fuel pump into my sil.. I know it's ftw coz it's from shane :P
And there we have it kids
baahahaha that is dodgey as! and to think all that woulda needed to do is grind the bracket a lil & grab a fitting for the pump :blink:
no wang, i was thinking helmet or maybe bullet proof vest and chained pants lol
Hey ppl that know me ... and strangers
haha OKAY...
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
