i take it this happened when you lot were on the piss out somewhere?
All of them bar me and another mate, yeh.
A mate got teh Gin bottle out, and thought they would mix "Gin and Juice" coz Snoop Dogg does? lol. There Gin to juice ratio was a bit out, and finished them off.
come on people, they'll be here soon!
so far suggestions are:
1) answer the door naked, and ask them, " Are you here for the gangbang"
2) call building management
3) Shoot them
4) Call security?
5) ring cops - tresspassers
6) beat them
7) bucket of water and if avalible add coloured cordial and open the door and throw it over them!
8) draw a pentogram and stick it to the front door and hope they're jehova's witnesses
Tell them your Jewish?
bahaha yea tim and the gin and juice......
Tim tried to tell Jamie an I the other week that he needs an ex/waste gate to stop boost flare :thumbsup: We let it slide.... Untill Sat night. If it wasn't so dark I would have got on him cam trying to explain what this said boost flare problem is...
To be honest I still don't know haha.
We think in short, he just wants the gate so it can go DOODOO CHHAA DOOODOO, hahaha.
and all this from an ex mechanic...its scary
his car is reasonably stock isnt it?? I didnt really talk to him bout it the other night..
Stock.. and he wants a top mount and put stock turbo back on, with ex waste gate, so its more easy to upgrade later?
Wont listen to me, or anyone. Oh well.
does he bat for the other team? :thumbsup:
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
