HAHAH true that. I'm comming down for New Years as well, f**king guna run a muck.
That chick looks hot from the back hahah, 10 points to the dude
Thats all thats important isnt it? What they look like from behind!
Finally, I get my R33 tomorrow! F*ck yes!
Got any pics or more details mate?
Stylish Shot =P
Corner View
Arse Shot
Front View
Inside Shot
I've had it under contract for weeks now, waiting for finance to come through, well. It came through about an hour ago =D.
Like in my sig, it's a 1993 R33 GTS-T with 73,000kms on the clock.
Stock as all the way through and is in perfect nick. One Japenese owner, it came off the boat about 3 months ago. Full RWC and yes, the import plates are still shiney =P.
It has fat as tyres on the back and it's been factory lowered. Thats about it, apart from the fact some bastard stole the gear knob so it has a shitty one on there =P.
Ok, let me see if I got this right........ a 1993 with 73000 on the clock???
Let me guess, it came from a dealership near the PA Hospital?? Not saying it can't happen, but you have to realise how rare that is........
Actually I didn't realise it was that rare, makes me feel even better =D
Hahah, when I got the Nova, it only had 72 on the clock, thus being a 91 too.
But yes, you shall all see it and see the kms and see that I am not a lying whore =D hahaha
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
