Good morning peoples!! What a lovely day!!
Yes, I just woke up!!
pfft thats a poor effort dave, I JUST GOT UP :D
good morning bishes :sick:;)
P.S yes, i didnt get to bed til 4:30 this morning, and yes i was putting the adapter plate on :rofl: but yes it slightly doesnt fit, but yes i can modify it so it does fit :)
pfft thats a poor effort dave, I JUST GOT UP :O
good morning bishes :):D
P.S yes, i didnt get to bed til 4:30 this morning, and yes i was putting the adapter plate on ;) but yes it slightly doesnt fit, but yes i can modify it so it does fit :sick:
HA HA HA
i knew it...
but thank your lucky stars that you can fix it, remeber shane dont use that crapy instant gasket on it use aryldite :rofl:
Anna Wonderful??:)
ha ha ha
thats only cos your going on a Date with her on friday ;)
nah she alright but i think i have the loudest vomit and i have it on tape to provit :rofl:
HA HA HA
i knew it...
yeahhh, it can be done, but its a bit dodgey, as the plate is 5mm too short on one side (it just so happens the side where the farking diff mounts in the sump) and the holes for the bolts will be right up against that edge :D
wheres my bloody magic wand when i need it ;)
bring them to qld and we will find out which is better then
IS that a Challenge John?
I'll get my hands on a couple of boxes then well do a head to head taste testing comp.
yeahhh, it can be done, but its a bit dodgey, as the plate is 5mm too short on one side (it just so happens the side where the farking diff mounts in the sump) and the holes for the bolts will be right up against that edge ;)
wheres my bloody magic wand when i need it :rofl:
that sucks man but your not getting it redone again?
so will there be more progress or do you have to fix this first?
yes, that is a challenge and though u may be a bit 'wider' then me
bring on the challenge dude.
come time to out eat anyone with donuts, i win all the time
mawahahahahah
mawahahahahah
:laugh: i dont want to see who can eat more donuts ;)
i want to see which donut is better :laugh:
KK's FTW!!
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
