rather than a grinder I would be saying hole saw it makes a nicer modification (I did this with my 200 makes it look better and easier to do)
yeh n no, depends how good one is with an angle grinder. plus with a hole saw (they cost a fark load for the required size) u dont know exactly where the pipe is going to go through
hey bryn and troy..
i've got the next 3 weeks off work and some money burning a hole in my pocket..hmm what to do :thumbsup:
isaac, i'll PM u my bank details, u can store ur money in there :laugh:
isaac, i'll PM u my bank details, u can store ur money in there :thumbsup:
nah just send me your atm card and pin, i'll take it down to the bank and transfer the money into your account, thats how nice i am :laugh:
but seriously, i'm not sure what to do, was thinking of doing one of those v8 supercar experience things, or that wrx experience rally school... or just sitting round the house, drinking heavily and shouting.
Having done the WRX experience, I would definitely do the V8 one as the Rally one was crap!! I got to drive 4 laps in a 5 hour period........ bored out of my skull. And the price was crap too. I complained afterward and was offered to do the SAME thing again!! Now why would I want to do that????
:thumbsup: that sucks ass... although i think the v8 one doesnt' use a proper v8 supercar, its a standard ss they just strip out and slap a rollcage in, would still be fun tho!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
