LOL, you wanna be careful Col...you're showing your age there by knowing about Kris Kros :D :D
lee, to fix your avatar problem,
hold down the shift button and press the refresh button up the top of the browser at the same time. that`ll change your avatar image your viewing from your old one to your new one.
Coz of caching eh John?
Morining Ladies
Dont be a Scrooge Lee :D
man i dont even celerbrate it....
are you a Jahovas Witness or sumthing??? i know they dont celerbrate it either and they dont celerbrate Birthdays aswell :D
Lol im no Jahovas Witness im roman catholic i just dont like xmas its just a excuse retailers use to get us to buy more crap
Shane, who do u suggest to rebuild a dog box, just for future reference..
i cant answer that one caus i havnt had it done or havnt heard any reports from people who've had it done. ask mark from godzilla, he'll surely be able to tell u (thats if ur still getting ur work done there)
lovely bit of editing there col :D
lol godzilla dont know shit about 2jz, the guy helping ME build the car has built a few supras, little private guy... knows his shit.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
