I was of the understanding it was party time at your place...
yes thats what i hear too :laugh:
No one cares about skylines anymore, I think a MX5 with and angry rotary sound would get heaps more attention
Well from those who know somthing about cars anyway, the GTR will still pick up lots of 16 year old boys who think GTRs are invincible.
The conversion has been done before, I think thay had a few problems findin a gear box that fits but apart from that everything was sweet
ur a hater >_<
I still cannot believe IanB is giving GTS-T's a hard time after his pwning last night!! I had to slow down to 60k's and wait a full 30 seconds for him to catch up on the twisty bits coming down from Nebo to Samford. Just face facts Ian, the GTS-T is just as good when it isn't raining!!!!! My car is heavier and has less power but the suspension work is where the gains come on the twisties!!
put the same mods on both a gtr and gts-t and then go back racing...
"put the same mods on both a gtr and gts-t and then go back racing..."
I see your point Shane, but what choices are made by owners and in which direction they go is entirely up to them. Some (most) want straight line speed while others want a car that handles. I have opted for a little from Collumn A and a little from Collumn B.
And I'm still not happy with some aspects of my car (don't mention the paint!)
You are spending a motza on your engine and taking a long time to do it, but have you done any work on the handling??
this was the exact same questions thrown at me from Anna when i first started moddin the car.
i only recently notice how much work needed to be done to suspension because of the down force on the rear stock suspension.
the only reason i touched the engine is that 2 weeks after i bought it, it went bang! i always intended on doing the 3ltr conversion (i just happened to have a block in the shed waiting) and i thought im not doing it again, so may aswell do it while its out.
also i'll have the suspension and brakes upgraded by the feb 2 track day >_<
but in all honesty, i woulda loved to have kept my gtst, and looking back at pictures of it, im thinking about buying it back :laugh:
Dave...
I went slow on the samford leg for quite a few reasons... I was out of fuel and very out of breaks. Besides, once you go past jollies you get into nebo village and there are a fair few people there sleeping / living there, I like to keep the speed down through there so as to not piss them off.
Will see how it all go's once I get the coilovers and break upgrades in.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
