hmm true.. but then it would look like im lying or something and he could proably sue me for legal costs or some bullshit
i remember a while ago you got assaulted at the trainstation didnt u shane? anything ever happen with that?
true true
nah got mugged on the way to the train station. filed a report, cops took photo's but couldnt do anything else caus had no way of finding out who it was that did it. (no cameras etc)
my mate just pointed out that if the guy goes to court and pleads innocent i gotta front up to court with a lawyer...
i want to see this guy get pwned big time but will be more hassle than hes worth
give me his details if you really want to sort it out, i wont have him beaten or anything, but i can get compensation out of him for you :laugh: it wont be through the legal system though
Get free legal counsel.
I got rolled once by some 20-somethings when I was a little kid (15 - what sort of lowlife gangs up 3 on 1 on a kid half his size over less then 10 bucks?) - they were too stupid to steal my mobile phone however and I walked round the corner and rang the cops... the scum who did it are now in jail, and it didnt cost me a dime, police represented me.
That being said, most of the work was done by southbank security. They are the ones who detained the scum, they built the case and all the cops did was rock up, take custody of the scum and summons everyone to court.
hmm well might as well go down to a station and have a talk to them at least... i'm sure they can answer the questions i have and what'll happen
im thinking what if i was some old man, or what if i had kids in the back or something - ppl like this clot need to be put back in there place or society is only going to get worse!
society is already at its worse dude.
it only gets worse from here onwards, never any better.
yeah but if everyone rolls over and does nothing then the ferals take over and things get a crapload worse than they are now
like i said, you want justice you have to do it yourself
i know i know, but i dont have enough info on him. Only thing i could do would be to stake out where i saw him this morning and see if he comes back.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
