hmm anyone intersted in a half day fishing off the gold coast ? I am going wanted to see if I could get another car nut to come with me :)
http://www.redballoondays.com.au/experience/FFC581
if this is the same Eddy (aka EnGaGe)? if so yeah he does have a black 33.
Yes the one and the same
*e-touch* dont tell marc
OK *shhhhhhh*
same person i'm thinking of?
Dunno LOL...I'm referring to the charming beauty Marc previously had as his avatar *shudders*
She's gone? still showing up on my pc. Damn caching proxies.
SUX2BU then :)
I got bunny straight away :)
i would go ply wood personally. i used to use a lot of it for modelling purposes when i was younger. cheap, fairly strong and not too heavy. eithere that or mdf. check prices really, both should do fine for what you need
bit of a spoilt brat, mommy pays for his shit.. wanker.. absolute wanker..
bought rims off him..
yeh, thats him!
bet he hasn't done any shit to it though like he said he's done.
his mum spoils him hey? i would of thought it be his super-daddy lawyer he has.
rofl
i'd go with ya this wk as there is barely anyone here in the office to provide any work for.
but, unfortantly all my $$'s is being invested into my new railway system im building at home :)
yes but in event of water the wood won't swell (ie when you build your mountains etc).
yes, i could just make a small pond out of plastic from a mold and do this.
but then that would involve filling it up every now and then from the water evaporating.
that i would think would be against water restrictions.
lol
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
