lol pfft what?.....attached?...married?
im sure you know stacks of single people....
either that or yo havent met like the 50% of single people out in the world (rough estimate of mine :P)
yas were both very lucky, i appreaciate him everyday for being in my life hehe
ok getting all mushy in here
easy there steph lol no :):):kiss: mushie mushie stuff please :laugh:
im gona buy that CF bonnet in the classifieds for my 20th which is coming up in a few weeks.
Cause I can.
Monthly pay is shit, but hey, its a big paycheque, I could respray the skyline once a month if I didnt have to put fuel into her or eat or make repayments on the loan I took out for her....
Cause I can.
Ian make sure CF bonnet is ADR approved or Mr plod will be giving u some living with his night stick :laugh: lmao :) Custom Carbon is the only crew I know of that has a few bonnets ADR aproved...
lol yeah food is good mkay
I dont think it is ADR approved.
Is there any way I could get it to be legal? Bonnet pins? Anything I can do to legalise it?
it needs a full frame not just the outter skin + has to go through the ADR's test center to be legal :laugh: thats the only way
As in you have to crash test it.
I have seen this bonnet before tho, I dont think its custom.
yeah well sorta due to the fact that if its not made the right way once it cracks it becomes a knife on the edges & can do more damage to people, lest thats how I under stand the rule
just like the clear tail lights & head lights have a look at some of the crap out there, ADR's approved lights have a set number to say yes these light comply to the ADR rules its the same for every thing
hey shane never seems to work he allways seems to be working on cars...
Hows he do that?
get home at 6pm, have tea and work until ~12pm, if i get on a role ive finished at 4am :laugh:
Maybe I will start droping in on shane to see how hes coming along on his rebuilds
Should keep me entertained for say... I dont know.. the rest of my natural life?
hahah no1 likes a smart ass :)
damm i wish i could find a gf like you.. IanB is a lucky man
I hate being single these days as most of the people i know are attached or married.
troy ur soft, go out, get pissed, shag some random and u'll be fine!
Ian make sure CF bonnet is ADR approved or Mr plod will be giving u some living with his night stick :) lmao :O Custom Carbon is the only crew I know of that has a few bonnets ADR aproved...
that's the lovely thing with r32's, if its a 1989 model, the CF bonnet ADR doesnt apply :P:D:D:D plus not many people could justify the 3k for an adr approved one :kiss:
plod aside, how dangerous are these things really?
don't have a crash & your fine just don't go trying to smash any land speed records & you'll be fine too would not use bonnet pins on a CF bonnet though
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
