Mike what did i say Beenleigh is no where near the Ghettos, da ghetto wopuld be the whole darra inala area, and bogansville is deffinately @ the Switch!!! ha ha ha thats why shane loves it out there!!!
lol true, but i there are so many bogans out here its hard to believe there is such a thing as civilisation, except for the hot girl who works across the road, mmmmmmmmmmmm :laugh: and she makes good food too :laugh:
lunch was good :) but gone >_<
just exterior really needs to be done i think.
got an idea of putting yours and IanB's together.
2x r32 gunmetal grey gtr's together.
hmmm i'd want want engine bay shot aswell >_<
i'm going to get a set of TE37's so if u give me a date u want to take the pics, ill organise that
also where would i need to take my car? would it be possible to do something with my backyard?
We can leave these ones till last.
We can probably more then likely do something in the backyard.
Just have to organise a colour backdrop so we can easily cut the car out from the photo and drop it into the other photo of where we will photoshoot ian's car :)
cool.
well if both mine and ian's cars are gonna be in the same pic, i'm gonna have to polish ian's car, caus sorry ian but urs looks dodgy as currently! :laugh:
might have to use you as my wing man on all photo shoots to wipe over any dirty cars and polish them up for me :D
bring ur car to me with a bottle of grog, and leave it with me for the day...
Hmm sounds very tempting, my car badly needs a wash. :laugh: but i might watch you doing it so i can learn to do it myself, and to make sure u dont blow the head :D
u just want to see me in my bikini dont u :(
if ur serious, i'd need to start at 7 so its not too hot, or it wont come out all that good (wont be able to shamois it properly, and the wax will prolly haze up and wont set)
Hmm thats sounds really good, Bikini? Pfft its nude or nothing :laugh: lol,
If you are being serious, i would love to take you up on the cleaning offer, just let me know what bottle of grog you prefer
JOHN, whats the go with the calendar?
read the thread dude.
all updates are in there.
im in the process of talkin to someone about it right now.
we are goin to take a bit of a new angle of who's goin to organise the prints, etc.
but i`ll be doin all photography work on it
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
