But it can be easily changed...it is afterall just a tickbox :)
Rules also state that no flood control will be removed if abused...
it just kicked in..... Karen :D un tick mine PLEASE!!!!!
PLEASE!!!!!!!
i'll be your best friend!!!! :D
Ummmm whats this you're talking about? :D
girls can get a rod inserted into theirarm, it acts as a contraceptive apparently, not sure on details. most effective one to date too apparently
Lightning Rod!!! makes Sparks shoot out her ass when you poke her and he Nipples light up :D
seriously
Birth Control....
that implant thing thats spose to last for 6 months or so.....
its tiny they do it at the doctors its like 1cm long.
you cant even see it.
go for those catholic girls who cant take the pill cos they dont want their parents finding out their having sex
i only want black....
so how much can u organise a set for me with only leather and nismo emborrided?????
none of this vinyl crap!!!!
i will ask her but she will prolly need a template, he he he i havent talked to her for a while, some "incident" we had
hehehe
Christian looks after the donation bits and pieces :)
but i'm a tight ass....
seriously
Birth Control....
roflcopter :) nice one lee :D lasts for two years or so
wont be after mikey's finished with ya.
cops seem to make things bigger then what they really are these days
that wasnt the case with you john, you were just small full stop :D oh wait, that was the front, oops :D
thats what i said, only about 3cm long apparently
roflcopter :D nice one lee :D lasts for two years or so
she got the big one!!! me and Linh went to the doc to ask about our choices and he showed us.. cant be to carefull now...
babies are the devil! the process is good, except for after the sex, then its all downill!
dont mistaken me for shane thanks :D
ah, you all look the same in comparison to me - "what the hell is that, sorr, where is it?" :D and chuck norris of course
Edited by lilmike86
:D
not ready for a kid yet, i a few years i will be though....
gotta get the wedding over with first then a house then i'll think about the kiddies
(:) that sounded wrong oh well)
but in the mean time i'm just gonna have to practice making babies! :D
oh did you know that the pill and that implate apprently get affected buy Achole?? so if your every out drinking and pick up, dont be a fool Wrap your tool....
trust me i happend to this chick i know, shw thought she was protected and now she's a mum, be it a Hot mum but still a mum...
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
