Ummm, what about Steve Parish?? He's professional in my book.
I think by "professional" Mike means someone who photographs for a living, not someone who enjoys it as a hobby.
professional in that case would mean someone whos made a name for themselves in photography and does it for a living.
lol im only taking the piss, u should know that :P
and if u want an example of a professional, take me for example, im THE professional :P
$2 suckys dont get u professional names in that industry dude.
this is the 20th centry.
not the 70's where chicks did wat they wanted to get in front of the camera.
damm playboy ho's
a professional is someone who has ALL the equipment and can bring out the best in an image. if you compare them to a hobbyists, then you can see the difference. its always the slightest things that make the bigger difference. just my opinion is all
hmm mite meed to use ur head next time :P
want an invite karen? :P
true, well try it tonight then :no:
damm playboy ho's
um, john, were in the 21st century as of 7 years ago
i aint all that interested in goin out an buyin myself a 20g camera just as the base along with another 10k in lenses, etc....
im happy with my $700 camera and $300-$400 in lenses i've spent.
this is a hobby and with that amount already spent on the camera which i wont be gettin back at all, i aint goin to call myself a 'professional'.
but i do know that from what i have seen in my own photos dude... they've turned out better then what i've taken before and like i said, there are a million angles to take a photo of a car.
I had a client once, who used to shoot for national geographic and numerous surf mags, over $800k worth of gear. Now, THAT IS CRAZY STUF!
You photos don’t look too shabby in comparison to most of the newbs on here.
i'm not criticising as such, i'm just saying, that with better equipment you get better photos. they look good john (well when finished they do) its just my opinion. then again i dont think people want to be paying more because someone wanted higher quality photos.
You weren't being asked ;)
OK then A cup is not flat :no:
PS DD FTW :P
yes but i just knew u were awaiting my reply :no:
n u know they are an A cup for a fact? we could get in trouble if we keep this up :P
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
